Allis C front hub grease seals
jk
03-29-2005 15:53:48
i just changed the fonrt hub grease seals in my 42 c. the seals are strange looking. my question is, after the seal is installed in the hub and the hub put back on the shaft, should the seal spin with the hub, or should it stay "rigid" like the shaft the hub mounts on?
jk
jk
03-30-2005 15:23:44
 Re: Allis C front hub grease seals in reply to jk, 03-29-2005 15:53:48
ok so how do i make the seal so it won't spin with the hub? what will happen if i dont do anything to fix it?
TBAMA
03-30-2005 17:36:53
 Re: Allis C front hub grease seals in reply to jk, 03-30-2005 15:23:44
Use your pocket knife to trim the felt so that it doesn't fit the hub so tight. Also grease the felt well. I don't know if this is the proper way to do this but I had the same problem when I did mine and this worked for me. No problems since. If the seal is allowed to keep turning on the axle, I would think it would soon cease to be a seal. Also, it might damage the axle.
TBAMA
03-29-2005 17:10:00
The felt seal is on the outside of the seal assembly and the hub actually spins on the seal. The seal is rigid on the axle.
Joe M(GA)
03-29-2005 17:38:57
 Re: Allis C front hub grease seals in reply to TBAMA, 03-29-2005 17:10:00
TBAMA is correct, my fingers and brain don't talk before they hit enter!
Joe M(GA)
03-29-2005 16:55:47
It spins with the hub, same as a G,B,C, and CA
never really understood way they went with that design!
Joe M(GA)
03-29-2005 16:55:33
whking
03-29-2005 19:57:32
 Re: Allis C front hub grease seals in reply to Joe M(GA), 03-29-2005 16:55:33
That seal on the front wheel does not spin with the hub. I have a CA AND THE HUB SPINS ON THE SEAL, IT HAS TO BE DRIVEN ONTO THE SPINDLE
