allis chalmers
mickie nelson
03-28-2005 19:08:07
I have an old Allis with serial # WC12658
I would like to find out how old it is and any other info that is available on it. I just don't know where to look for the info. Any help would be appreciated. Thanks in advance
John (MO)
03-30-2005 05:44:07
 Re: allis chalmers in reply to mickie nelson, 03-28-2005 19:08:07
Saw a pretty nice restored unstyled WC with narrow front, electric start, no lift and on rubber sell 3 weeks ago for $1700. Thought that was a good deal. A styled parts tractor with no motor, on rubber, with lift brought $150 and a pair of spoked steel wheels that I think were AC but not sure also brought $150. Unstyled WC"s are my choice for best looking of all unstyled tractors.
acmfmh
03-29-2005 11:25:00
I think one thing that was missed to tell you is that you WC is an "unstyled". Effective in late 38 with a serial number in the 74k's, AC began to make the WC styled. They gave it a round grill and different hood and fenders. Some other changes happened with the magneto shutoff and choke arrangements later. Started and lights eventually became standard. So, as most off us WC owners have found, depending on what you are looking for styled and unstyled doesn't matter. Just do your homework on what it is you are looking to find.
1937WC
03-29-2005 11:02:25
One source is the public libruary. Mine had repair manuals that were very helpful to us. My grandfather bought a 1937 WC in the spring of 1938 that I learned to drive on in the 50's, but as the need to get farming done quicker it was cast aside into the grove and weeds and the engine became stuck. My father is a healthy 87 and last summer/fall with the help of the manual dad and I were able to get it started after 30 years of sitting. It wasn't cheap, but working on it with my dad.....priceless.
John (MO)
03-29-2005 08:44:25
Mickie, email me directly I can point you in the right direction.
Texas Denny
03-28-2005 19:30:26
You are right. It is old. The serial number indicates that it was built in early 1934. Another book I have says late 35. Regarding information, it would be a lot easier for you ask what you want to know. All information would fill a couple of books.
Allis built 178,202 WC tractors and was their most successful model. When Nebraska tested the WC in 1934, they found 21.5 horsepower on the belt and about 13 at the drawbar. They did about 15 tests and these are the results Wendell published. Often the tractors did much better than the numbers he published. Fo instance, the WC was again tested when they changed the sheet metal in 38. It showed 31.4 on the belt and 25.6 on the drawbar. I don't think they changed the motor.
I've got a 1947 WC. I've got books manuals etc. I left my email open.
ACEd
03-29-2005 06:05:59
 Re: allis chalmers in reply to Texas Denny, 03-28-2005 19:30:26
As to HP, there are a number of things that make the differences real - most significant is Compression Ratio that changed over time with early tractors being lowest CR and lowest HP. This change occurred as gasoline evolved to "higher" octanes, but Hand Crank versions still tended to be low CR (4.x:1 range). Also, tractors set up with dual tanks to start on gas then switch to main tank to burn Distillate (or Kerosene - hence the K or KA suffix on Motor S/N on block) were common into the 50's - these were typically still in the mid 4.x to low 5.x range in the 50's while the gas hand cranks of the 30's were in the 4.x range but migrated with electric start to 5.x range in the 40's and then to 6.x range and maybe higher depending on tractor in the 50's. LP fueled tractors were typically even higher in the 7.x range or higher. Also there were other factors such as increasing RPM over same time frame which significantly influenced HP.
Texas Denny
03-29-2005 06:22:29
 Re: allis chalmers in reply to ACEd, 03-29-2005 06:05:59
Thanks, I suspected this but could never find any real data. I know the bore and stroke were constant. And I know the head was always flat. So the answer is the piston and how many different pistons were there. Probably, that would be hard to trace. AC probably didn't continue to make all pistons when newer ones were released.
ACEd
03-30-2005 09:52:30
 Re: allis chalmers in reply to Texas Denny, 03-29-2005 06:22:29
I complied a list from Norm Swinford and AC Dealer books I have for WC & WD - I will try to attach it, but it this fails, send me an e-mail and I will send you the word document. Also changed Carb Size in late WC and 1300 RPM WC vs 1400 RPM for WD.
W Prefix Engines (as used in WC Tractors) - note I have a 1951 WD-Thomson HC tractor with engine W200527K K Suffix Dist 1300 (4.2:1) G Suffix Gas 1300 5.0:1 KA Suffix Dist(Late) 1300 4.6:1 (4.5?) HA Suffix Dist High Alt 1300 5.0:1
WD Prefix Engines (believed to start at Engine WD201126) (Note: GA changed to PA as default for Gas beginning at Engine WD283022 circa 1951 Tractor WD76000 +/-) K Suffix (KA?) Dist 1400 4.6:1 (4.5?) GA Suffix Gas 1400 (5.5:1) PA Suffix Gas (Late) 1400 5.7:1 HA Suffix Dist High Alt 1400 5.0:1 BA Suffix Gas High Alt 1400 6.6:1
Pistons
WC,WF,W25 Low Octane Fuel 4.2:1 (Cast Iron) U-3114
WC,WF,W25 Gasoline 5.0:1 (Cast Iron) 204462
WC,WF,W25 Gasoline or Butane 5.5:1 (Cast Iron) 207909
WC,WF,W25 Low Octane Fuel 4.5:1 (Aluminum) 223505
WC,WF,W25 Low Octane Fuel High Altitude 5.0:1 (Aluminum) 223507
WC,WF,W25 Gasoline 5.5:1 (Aluminum) 217311
WC,WF,W25 Gasoline High Altitude 6.6:1 (Aluminum) 224754
WD Low Octane Fuel 4.5:1 (Aluminum) 223505 223504
WD Low Octane Fuel High Altitude 5.0:1 (Aluminum) 223507 223506
WD Gas (Eng prior to s/n 283022) 5.5:1 (Aluminum) 217311 217282
WD Gas (Eng s/n 283022 & Up) 5.7:1 (Aluminum) 224917 224916
WD Gas High Altitude 6.6:1 (Aluminum) 224754 224753
ACEd
03-30-2005 06:29:46
I believe the B's also used a trick of double head gaskets to lower compression - I'll have to go back and recheck book
mickie nelson
03-29-2005 04:50:20
I am not sure what all i want.I have this tractor and i would like to make it look new again.
where do i find books for this.also would i be out
of line to ask you more questions as they arise?
I don"t think i have your e-mail address.
thank you so much
Texas Denny
03-29-2005 06:24:03
 Re: allis chalmers in reply to mickie nelson, 03-29-2005 04:50:20
Yes, by all means. My email address is open. Right click on my name and select properties.
Rod (NH)
03-28-2005 19:23:29
Hi Mickie,
Over on the left on this page is an entire section titled "Research & Info". In that section, click on "Serial Numbers", follow the appropriate links, and you will see that it is a 1934. I don't know anything about the WC so that's all I can help you with.
third party image Rod
mickie nelson
03-29-2005 05:04:25
 Re: allis chalmers in reply to Rod (NH), 03-28-2005 19:23:29
thank you rod
