wd 45 hand clutch
Little Ed
03-26-2005 06:31:49
The hand clutch on my 45 is not slipping, but when the lever goes all the way forward, it tries to drag the tractor along, like it is trying to engage again. Would this be adjusted out by the turnbuckle at the base of the hand lever?
David from IA
03-28-2005 14:31:32
 Re: wd 45 hand clutch in reply to Little Ed, 03-26-2005 06:31:49
Had the same problem with my 54 WD-45 found the hand clutch had excess clearence between plates. Removed the shims until I got the .030 clearence.
Another thing that helps when you park the tractor for the night engage the hand clutch it keeps a majority of the oil out of the clutch.
Texas Denny
03-26-2005 13:30:25
I've had 2 WD's and a WD-45. They all had a little drag when you released the hand clutch. It is normal. You can't really use the hand clutch for shifting. That is especially true for the D series tractors. It was also true on my CA.
wdtom
03-26-2005 12:31:11
The adjustment you mention is only to position the lever where you want it. Is what you describe due to the oil between the clutch plates? You generally have to use the foot clutch to shift or put it into gear, at least until the oil is good and warm, probably then too.
Little Ed
03-26-2005 20:20:54
 Re: wd 45 hand clutch in reply to wdtom, 03-26-2005 12:31:11
Thanks,guys. Since it seems to be pretty common, and the clutches run in oil, I'll not worry too much about wear. It has done it since we first got the tractor, in 1972. I added some Wally World oil to it last fall, and it got worse. But I was able to use it for a few hours today,and it worked like it always did.
