3 point lift adjustment on 200 AC
jra
03-24-2005 07:24:30
I'm trying to adjust the implement postition my 200 Ac. I first set the tortion bar, then set the traction booster link, the one that hookes to the lift arm, checked feed back spring for 11', then tried to set the implement postition rod, the one that has 2 springs on it. my book says to back the adjuster nut off untill the lift arms riase to the top, then turn it back on rod untill the arms drop 2", however, I can back the adjuster nut off all the way to end of rod and the arms will only lift about 1/2 way up. I can push the rod forward with my hand and the arms will go all the way up, so, I guess there is something wrong with the linkage.Anyone have any ideals as to what is wrong? week spring on adjuster rod? traction boost not set right?
