Ronnie in TX... TSV Carb
Glen in TX
03-23-2005 14:23:21
I need the float setting for the Marvel Schebler TSV carb used on Allis G and MH Pony. A copy of any kind of specs on this carb would be helpful. They quit putting spec sheets in the kits? Thanks.
Ronnie in TX.
03-24-2005 07:51:12
 Re: Ronnie in TX... TSV Carb in reply to Glen in TX, 03-23-2005 14:23:21
Glen:The float vevel should be set with the float 1/4" from the top edge of the bowl or 1/4" between the bowl gasket and the nearest edge of the float. The idle needle is set approximately 1-7/8 turns open.The float may be set by bending very near the fioat axis,being sure not to cause the float to strike the edges of the bowl.
Glen in TX
03-24-2005 10:30:42
 Re: Ronnie in TX... TSV Carb in reply to Ronnie in TX., 03-24-2005 07:51:12
Thanks Ronnie ! I figured you would know with your experience on that carb. You sent me all those TSV carb pics when I was searching the other year. Where are you located again anyway? Thanks.
Ronnie TX.
03-24-2005 22:18:30
 Re: Ronnie in TX... TSV Carb in reply to Glen in TX, 03-24-2005 10:30:42
Gilmer Texas.
Glen in TX
03-29-2005 13:00:16
 Re: Ronnie in TX... TSV Carb in reply to Ronnie TX., 03-24-2005 22:18:30
Ok, lol. You are way on the E side and I'm on the W side of panhandle by Friona, SW of Amarillo almost in New Mexico. Zenith factory folks promised me some info to put in the kits I buy from them to sell but nothing from them yet. May have to just write my own directions? Wish I had saved copies from the other old kits.
