7030 Allis repair problem
Bill Novak
03-22-2005 09:23:36
We have a 7030 Allis, it up and died one day. It starts, but doesn't move. He split the tractor thinking it was the Hi-LO, it wasn't. He replaced the hydraulic pump, and checked the valve. He put it back together, and still does not move. He's at his wits end! It also makes a whining noise. If anybody has any ideas please email us, we are getting desparate, we need the tractor up and running again Thanks
BP
04-13-2005 21:35:36
 Re: 7030 Allis repair problem in reply to Bill Novak, 03-22-2005 09:23:36
Hi, Did you discover the problem with your 7030, mine just did the same thing the other day. My transmission oil pressure light came on and I lost all hydraulics, including the power steering and the loader. Also it won"t move. So far I haven"t found the problem.
STONEY
03-23-2005 22:07:44
The splines in the power director hub are stripped out.
glr62
03-23-2005 11:56:06
curious why hydralic pump was replaced?
what condition was torque limiter in?
is the range transmission in gear?
Bill Novak
03-23-2005 14:40:21
 Re: 7030 Allis repair problem in reply to glr62, 03-23-2005 11:56:06
Torque limiter in good shape, and the range transmission is in gear. Pump was replaced because he thought there was lack of pressure (power) to power direct. We took pump to a shop, they said it was junk. Trector whines, and you can put it in any gear, no grinding, don't push clutch down, can do this in hi, lo, and park. Any ideas, he doesn't want to have to split again, it's quite the job. Let me know. Thanks Bill
Bill Novak
03-24-2005 09:12:58
 Re: 7030 Allis repair problem in reply to Bill Novak, 03-23-2005 14:40:21
I call this the inching valve or power direct valve. At idle it is 195, at 2000rpm it is 225. If that helps.
glr62
03-24-2005 10:09:05
 Re: 7030 Allis repair problem in reply to Bill Novak, 03-24-2005 09:12:58
need to split again and look at splines on hub as mentioned before.
Bill Novak
03-24-2005 19:54:41
 Re: 7030 Allis repair problem in reply to glr62, 03-24-2005 10:09:05
Have you encountered this before? We had a so called professional go thru the power direct, assumed ok, so didn't check splines. Shaft was good. Maybe the place overlooked something in power direct.
glr62
03-24-2005 05:24:47
what pressures do you have at pd valve
