Allis D 15 hydraulics problem help
florin
03-20-2005 16:26:38
I have a D15 and the 3 point hitch left arm is leaking fluid. Just added 2 gallons and in 5 min of work it was gone again. Can anyone help me and give me a good idea how to fix this problem, and any idea on the cost for fixing it.
Thanks in advance to anyone for any help!!!
ron blan
03-22-2005 16:14:19
 Re: Allis D 15 hydraulics problem help in reply to florin, 03-20-2005 16:26:38
Sounds like you have a bad oil seal. Dont really know how difficult it would be to replace. It may just be to where you will have to remove the lift arm, drain the fluid out, and replace the seal. Getting the old one out may be a chore but one good thing about removing a bad one is the fact that you dont have to worry about damaging it. I usually end up prying the lip apart from the housing, which will squash the seal out of shape and will let it come out toward you. As far as putting the new one in, other than you dont want to damage it, you can usually get a socket that will fit even with the diameter of the seal, and started straight, will drive right in. Be sure that the seal you put back in is facing the same way that the old one was. Hope this helps.
