Sickle mower part needed
Mark in Mizzou
03-17-2005 07:29:40
I'm sending this for a friend who doesn't have computer access: Needing the strap that holds the pitman to the flywheel for a Mdl B or #5 mower. Any help will be very much appreciated.
Thanks,
Mark Hill
Dearborn,MO
Rod (NH)
03-17-2005 10:48:08
 Re: Sickle mower part needed in reply to Mark in Mizzou, 03-17-2005 07:29:40
Hi Mark,
Here's my thoughts on the B/C mower. I know nothing about the #5 mower. I have replaced those straps with new about three years ago on by B mower. I ordered the parts through an old local AC dealership so they should be available from your nearest AGCO dealer that supplies AC parts. If your friend is replacing them because of wear, I would suggest also replacing the mating cast bearing housing as the "tits" on that housing are also probably worn and would not mate well with the new straps, causing premature wear. That particular joint is one that needs to checked often for the proper tightness as any looseness or slop will cause early wear.
There are two straps. They are identical and both are needed. The part number for these straps is 301671. There is only one bearing housing that the straps mate up to. The part number for the housing is 308377. Tell your friend to be prepared for a price shock if he pursues new replacements. I can't locate the sales slips for my parts but I do recall those three parts were well over $100.
Used parts may be a possibility if you can find some but should be carefully inspected for wear before purchase.
third party image Rod
