WD Hand Clutch Question
Travis in PA
03-16-2005 10:00:55
What exactly does the collar do that goes around the hand clutch? Is it supposed to be a complete loop? Mine looks broken off at the front. It looks adjustable, why? By the way the tractor run fine. Thanks
Tramway Guy
03-16-2005 11:10:03
 Re: WD Hand Clutch Question in reply to Travis in PA, 03-16-2005 10:00:55
If you are talking about something that is about 6 inches up from the hand clutch pivot point, odds are that it is the 'kick out' for when a snap-coupler implement hits something solid..the impact will cause that mechanism to declutch the lever and stop the tractor in its tracks. It was optional equipment on late WD's and WD45's.
It was not made to go all the way around the lever.
