D17 HYDRAULIC PRESSURE
Harlen Larson
03-13-2005 13:13:10
DOES ANYONE KNOW HOW MUCH PRESSURE A D17 HYDRAULIC PUMP SHOULD BE PUSHING IF I DIRECTLY CONNECT A GUAGE TO THE PRESSURE SIDE OF THE PUMP?
Gatz
03-13-2005 15:44:10
 Re: D17 HYDRAULIC PRESSURE in reply to Harlen Larson, 03-13-2005 13:13:10
You didnt say which Series, but According to IT's AC-201 manual.
for D17s up to s/n75001 (SerIV)
Instll 4,000-5,000 gage at remote ram connection.
When lever is moved to raise postion, there should be a peak of about 3600 psi for an instant, then drop to 2100 psi and hold steady.
It is noted that if the pressure reads below 2100 or is above 2200 in the hold pos., the relief vavle should be overhauled.
This seems a rather narrow band to me, but it's what the book says.
SeriesIV has a different setup and uses ~ 2300 psi pressure.
You may want to get a manual that describes the system and outlines how to adjust the valve, etc.
Gatz
