Unstyled wc fender braces. Correct dimensions
Pappy (Wi)
03-12-2005 14:54:39
I have an unstyled wc I am restoring. I do not have the original braces that attach the front of the fenders to the tractor frame. Could someone tell me the exact lenght and diameter of the rods/braces? Are they threaded only on the ends or the entire lenght of the brace? Are they hard to make? I want things to look as original as possible. Thank you.
Bob in sw Wi
03-13-2005 20:02:31
 Re: Unstyled wc fender braces. Correct dimensions in reply to Pappy (Wi), 03-12-2005 14:54:39
Where in Wi are you? I have a friend that has alot of unstyled WC parts in Sauk county. I know he has the pieces you are looking for.
Pappy (Wi)
03-14-2005 16:22:30
 Re: Unstyled wc fender braces. Correct dimensions in reply to Bob in sw Wi, 03-13-2005 20:02:31
Bob (WI), I am from the West Bend area about 20 min NW from Milwaukee. How do I get a hold of the fellow from Sauk? There are other parts I need. Thanks.
Pappy (Wi)
03-12-2005 18:40:01
Gene, thanks for the reply but actually I am talking about the long straight rods (one for each fender) that stabalize the front of each fender to the frame of the tractor. Thanks.
JMS/MN
03-13-2005 16:04:06
 Re: Unstyled wc fender braces. Correct dimensions in reply to Pappy (Wi), 03-12-2005 18:40:01
They need to be long enough to hold the fender parallel to the tractor side frame. I made mine from half inch diameter shaft, threaded about 1 1/2 inches on each end. Make sure they don't stick out too far inside the fender and hit the tire. A bit of extra thread allows for lining up the fender with the frame.
gene
03-12-2005 16:03:07
Search this site using the term "WC fender brackets". My post is dated 5-29-04 and provides the measurements for the front and rear brackets.
