leroi 226 same as AC WD engine??
leroi
03-08-2005 18:14:44
I have a Leroi D226P 4 cylinder engine in a trencher that needs rebilding, I've heard the AC engine used in the "W" series tractors is the same. It sure would make parts scrounging a bit easier....Any truth to that vicious rumour?
leroi
03-11-2005 23:12:17
 Re: leroi 226 same as AC WD engine?? in reply to leroi, 03-08-2005 18:14:44
Thanks!, ordered AC gaskets, they fit just like the originals-nice to know
ken spink
12-19-2006 18:05:35
 Re: leroi 226 same as AC WD engine?? in reply to leroi, 03-11-2005 23:12:17
Is the crank the same too?
Kip[UT]
03-09-2005 19:05:59
You can use WD45 inrernals, gaskets, etc
Joe O(WI)
03-09-2005 06:12:10
Go to www.tractair.com. It"s a LeRoi website. If the info isn"t on the website contact Dan Perry Through the site. He is knows LeRois.
ACEd
03-09-2005 05:46:26
Be careful - first there are 2 somewhat different 226 Allis engines - the W226 (WD45) and the G226 (D17) variations. Supposedly they have different cranks and other internal parts got heavier duty in G series. Both were only available from Allis as Gas motors - as Allis chose the Buda developed Diesel which I believe was 262 ci. Anyway, if the D226 is a diesel, go lightly in using Gas engine parts as diesels generate higher pressures.
Jim ny
03-09-2005 05:13:56
I belive they are for the most part the same You should ask this question on Unoffical allis chalmers
