Realistic price?
M Nut
03-08-2005 09:59:30
I am looking to purchase a CA Allis Chalmers to put a 5ft grass mower under to use on my lawn. I placed a want ad in the classified ads and am wondering if my thoughts on price are in line, or way off. I thought I should be able to buy a CA in good running condition for around $2000. I would pay more if it was painted nicely and had new tires. Then I was thinking in the $2800 range. Am I at all where I need to be for purchasing a tractor at a realistic price? How about if I purchased a straight C Model. Then what should I expect to pay?
Thanks for any advice you can offer.
M Nut
JMM
03-13-2005 04:11:14
 Re: Realistic price? in reply to M Nut, 03-08-2005 09:59:30
I'm in the same boat. My problem could be your answer. I have a 1949 Allis B with a belly mower that I want to sell and not sure what to ask. Sounds like $1500 is reasonable. I don't know where your from or how far you would travel but I'm in Illinois. Has decent paint, runs good but has original crank start. Some people think that's a plus, some do not. If it's used regularly it starts first turn, if not we usually pull it. 20 ft. and it pops off. Anyone interested?
M Nut
03-09-2005 06:55:18
Thanks for the information. It sounds as though I should be able to get exactly what I want for my price range if I just look around a bit. Thanks for the idea of ebay. I have a trailer, and a little trip this Spring might be fun. (Although the price of gas isn't!)
ACEd
03-09-2005 06:14:48
Agree with jayw - but $2800 is too high unless it is perfect and comes with the mower you want ready to go - and even then -----
Main differences between C and CA are power shift adjusatble rear wheels and "live" PTO via hand clutch - if you buy a CA make sure hand clutch is in good condition - they can be expensive to fix.
A couple of other things to think about - if you are going to put a mower under it, you probably would be better off with a Wide Front than a tricycle - and if you are considering a C, why not a B - after mid 40's B's are same CE engine and power as C for a given year and later ones same as CA (higher compression than C) for year - B were made til 1958 so there is overlap - just be aware very early B with BE motor were less power.
Best. Ed
jayw
03-08-2005 18:25:39
Mnut youll find that all of us that own a Ca will tell you around 1500 dollars. But in turn most of us wouldnt take 2300 for ours. I quess its cause there such a sweet machine , I got mine for 1000 but ive stuck around 800 or so in it to get it were im happy and will probably stick 2 or 3 hundred more in it before it over.So ya see Ive got about 2500 in mine and most guy that are 100 % honest will have a little in there too.
Texas Denny
03-08-2005 17:20:23
I agree with A.Irvin. I sold my CA with good paint , excellent tires, a plow and and a dirt scoop for $1750. If you're willing to drive, you can get one on Ebay running good for $1000 to $1500. And the C will be less but should also do the job. I see C's on Ebay often with a 5' finish cut mower.
A.Irvin
03-08-2005 14:47:38
$2000 would be about the maximum you would want to spend, thats if the tractor runs good and looks good. Just to give you an idea, I bought a CA for $1400, had a decent paint job and after a carb rebiuld ran perfect. A C model would be easier found and probably bought cheaper. Both would do the job you want no problem.
