HD5 dozer please advise
weekend farmer
06-25-1999 16:14:36
I'm looking at a HD5 dozer. Runs strong, Pushes dirt real nicely. The problem is it doesn't turn right. When you pull the right clutch & hit the break there is no responce. Upon closer inspection the pin at the bottom of the hand lever is to small causing some play. The lever doesn't encounter resistance till well after the other lever. Could this be the problem. He wants $3000 as is. Is it worth it? What other possible causes could there be, & how expensive? I've only worked with old Farmall tractors, Dozers are new to me(so is the Allis brand but I hear good things)
Thanks for any advice
Weekend
Nick
08-05-1999 21:36:20
 Re: HD5 dozer please advise in reply to weekend farmer, 06-25-1999 16:14:36
check out the steering clutch adjustment, steering
clutch could be going bad. when It gets bad enough, It will let you know, It will try to run in circles. I had a lazy lever in my 3. Thats my experence. It didn't cost to much, I have a good friend who has 4 DH3 Parts machines.
