AC C Flywheel timeing mark
Dick L in NW O
06-25-1999 06:19:15
Can the flywheel be installed in more than one position. I just bought this tractor not running and I can not find the timeing mark feeling the piston close to the top on the compression stroke.
Brent Stapleton
06-30-1999 19:30:12
 Re: AC C Flywheel timeing mark in reply to Dick L in NW Ohio, 06-25-1999 06:19:15
I had the same experience. When the #1 is tdc, the mark "FIRE" will be found on the (as you are sitting on the tractor) left side of the clutch housing. There is a 3/4 inch hole that you can see the flywheel. Hope this helps.
Brian
07-05-1999 08:49:21
 Re: Re: AC C Flywheel timeing mark in reply to Brent Stapleton, 06-30-1999 19:30:12
Just wanted to add, the fly wheel probably could be bolted on in more than one way, but, it would not be possible to get all four bolts back in. I would like to think no one would do that, I hope!
Hope this helps. Brian
