Unstyled WC Tires
Bud W
03-05-2005 11:44:13
What would be the correct size front and rear tires for a WC with factory spoked wheels ?
Thanks
Leroy
03-06-2005 14:56:32
 Re: Unstyled WC Tires in reply to Bud W, 03-05-2005 11:44:13
per 1951 wards catalog 11.25 x 24 transwered up to 13x24 and that later transfered up to 14.9x24 so even tho people think the 13.6 looks better it is too small in width or height to equal orignal and with anything less you will lose speed and they are slow to start with
Leroy
03-06-2005 15:00:54
 Re: Unstyled WC Tires in reply to Leroy, 03-06-2005 14:56:32
Miller would not have that size, what they would have is 11.2x24 and that was the old 10x24 and there was no size to compair that with before, the 9.00x24 converted up to 11x24 and new size on that is 12.4x24
Bill(Wis)
03-06-2005 06:16:41
Original Factory rears were 11.25-24s. Miller tire has that size. They looked like a better fit than the 13.6-24s we used later.
Bud W
03-06-2005 06:26:52
 Re: Unstyled WC Tires in reply to Bill(Wis), 03-06-2005 06:16:41
I assume Miller's 11.25's are measured from sidewall to sidewall versus the original 11.25's that were true tread width? If this is true Millers 11.2's would seem to be too narrow?
Bill(Wis)
03-06-2005 08:53:36
 Re: Unstyled WC Tires in reply to Bud W, 03-06-2005 06:26:52
I don't know. A call to them should clear that up. I know that when our original 11.25s needed replacement, the 13.6s just looked a little too wide but things have changed since then.
Aaron SEIA
03-06-2005 05:19:00
Front 5.50-16, rear, most people go with a 14.9-24. I think a 13.6-24 would look a little better on it, but they cost a lot more than the 14.9's
Aaron SEIA
