D14 Electrical Problems - Smoking
Dan Driedger
03-03-2005 18:03:59
I'm having problems with my 12Volt D14. It normally fires right up but yesterday (when I needed to blow some snow) I got half a crank out of it then nothing. Turning the key still made a clicking noice which make me think the solenoid I replaced last year is still fine. Then I noticed that some of the "original" wiring was quite rotten so I replaced that today but still no success. I thought it might be the battery cables so I bypassed them with some booster cables but still no luck. Then something weird happend. I suspected the battery might have drained through all my monkeying around so hooked it up to a different battery and as soon as I did, even though the key was off, the tractor made half a crank, and then the cables started to smoke. (I quickly disconnected them)
I'm at a loss as to what the problem might be.
wilko
03-04-2005 20:16:29
 Re: D14 Electrical Problems - Smoking in reply to Dan Driedger, 03-03-2005 18:03:59
Not sure what you mean when you say that the cables started to smoke. If the smoke comes from the battery post/cable interface you just need to clean up the battery posts and /or cable ends. These tend to get a hard, black coating that doesn't conduct well. A lathe type cleaning tool works best.
souNdguy
03-03-2005 19:52:51
Disconnect wires from the switch and solenoid, and take your ohm meter to it.. might be a stuck/welded contact in the solenoid..
Soundguy
