speed patrol /WD clutch problem
old
03-02-2005 21:18:08
Well I picked up a WD for the engine for my speed patrol. Put the engine in and now I have no clutch release. What is up? I think the WD is around a 51 and the speed is around a 47. Did they use more then one type of clutch and haw do I fix the problem?
thanks
Kevin (FL)
03-03-2005 07:06:51
 Re: speed patrol /WD clutch problem in reply to old, 03-02-2005 21:18:08
You might need to give us some more info--a few questions here come up in my little mind:
1) Did you use the same pressure plate/clutch/throwout bearing that was already in the WC? In other words, was the WC running before the engine swap and was the clutch functional?
2) If you used new/rebuilt stuff, did you do a side-by-side comparison of the parts?
3) Is the clutch pedal going in normally and do you feel pressure as the fork/throwout bearing pushes against the pressure plate? If so, could the clutch disc be stuck on the flywheel--like what happens when a tractor sits unused for awhile?
4) Did you make sure the clutch disc slid freely on the input shaft of the transmission--maybe there were some burrs or something else that might prevent the clutch from easy movement along the spline?
I'm asking these questions to try and nail down where the problem is. I have a good friend in Wayne County PA that just restored a WC Speed Patrol--he can probable shed some light on any unique issues that might be causing the problem. I'll get in touch with him so he can read your first question and your replies to my questions.
Good luck with it--no fun fixing a tractor and then it won't work....
Posting Guidelines
These forums are for tractor-related topics. At all times treat each other with courtesy and respect. Off-topic posts are accepted on a limited basis: No politics, religious discussions or topics that contain bigotry of any kind. These usually result in unkind words and take away from the friendly, helpful nature of this antique tractor community.
old
03-03-2005 08:51:37
 Re: speed patrol /WD clutch problem in reply to Kevin (FL), 03-03-2005 07:06:51
Both engine/tractors where in working order. The engine in the speed patrol was just wore out/ no oil preasure and the WD engine is strong. I didn't unbolt either of the clutches, I use the WC throw out bearing and the WD clutch. I have no preasure on the clutch pedel and the throw out bearing itsn't going far enough forward to puch the fingers on the preasure plate. I think I probably should have also used the throw out bearing from the WD instead of the one fro the Speed patrol.
Kevin (FL)
03-03-2005 10:57:58
 Re: speed patrol /WD clutch problem in reply to old, 03-03-2005 08:51:37
Sounds like the T/O bearing might the culprit, but I would also compare the forks--assuming you're going to split it open again. I'll check with my buddy in PA to see if he has any part #'s or photos that might help.
old
03-03-2005 21:19:18
 Re: speed patrol /WD clutch problem in reply to Kevin (FL), 03-03-2005 10:57:58
Got it fixed the t/o bearing may have been the problem or an adjustment not sure but it works now
