wide front for C or B
GOT
03-02-2005 15:23:37
Any idea as to value of a wide front for a B or C? Are they the same? Thanks!
Eldon (WA)
03-02-2005 19:22:07
 Re: wide front for C or B in reply to GOT, 03-02-2005 15:23:37
The B non-adjustable "arched" front is standard on the B and are a dime a dozen. The adjustable wide fronts for the B are a little more rare, and usually are paired up with C type rear hubs for more variations in tread width. The C adjustable wide front is similar to the B AWF, both are worth $300+ I have all 3 types for sale...email me at [email protected] if interested.
Mark - IN.
03-02-2005 17:34:17
I may be wrong, and can't tell you the value, but unless I'm incorrect, no C's had wide fronts, at least I've never seen one. B's on the other hand all had wide fronts.
As for value? Good question.
Mark
steve(ill)
03-02-2005 18:54:26
 Re: wide front for C or B in reply to Mark - IN., 03-02-2005 17:34:17
All Bs have wide front, most C have narrow.
THe C wide front is a box section, adjustabel width. THe C steering has a gearbox under the radiator and the "rod" goes from under the radiator back to the steering wheel gear box drop arm.--- The B wide fron has a couple variations. Most standard it the wishbone which is a forged steel U shaped or ARCH. THe less common is the adjustable box section, similar in design to the C, but not the same. THe B steering rod goes from the left fron king pin (by the wheel) to the steering wheel gear box drop arm.---- For this reason the B and C are not directly interchangable. YOu can put a B alxe on the C if you modify the steering rod and arm, or change out the steering wheel gear box to the B style. Cost varies, i would think the B is cheap (less than 200) since it was the standard design and very common. The optional wide front for the C might cost twice that, unless you find a good deal.
suraj parkash
03-07-2005 09:45:45
 Re: wide front for C or B in reply to steve(ill), 03-02-2005 18:54:26
i have made the tsr program and when i run from the comma nd line c:\promt does not clear and display always even when clrscr() command
run plz tell me the solution how to hide dos promt tell me the solution immediately
Mark - IN.
03-03-2005 15:41:01
Hey Steve, I knew all B's have a wide front, and mine has a wishbone. I've seen the others on B's as well. I knew that C's steered in the middle as opposed to the pitman arm of the B. I've never seen a C with a wide, and figured that before I said that none had them, best thing to do was not. First thought was no way a wide would fit on a C with that center piveting post down the front like that, but then again with a strategically located gearbox with a center link, could be, never know.
I've never seen a wide front C though. Would think a rare.
Mark
steve(ill)
03-04-2005 20:09:27
 Re: wide front for C or B in reply to Mark - IN., 03-03-2005 15:41:01
third party image
this wide front on a CA is what the C woudl look like. not the same part, but same design.
steve(ill)
03-04-2005 20:11:08
 Re: wide front for C or B in reply to steve(ill), 03-04-2005 20:09:27
CA again?
http://www.tractorshed.com/cgi-bin/gallery/photo_pic.cgi?pic=http;//www.tractorshed.com/gallery/tphotos/a23634.jpg&firstrec=64&lastrec=79&Parameter=allis&mode=All&what=tphotos
GOT
03-03-2005 04:25:27
Thanks for the great info!
