WC BRAKE DRUM
Bud W
03-02-2005 08:41:11
I was replacing the linings on my unstyled WC and to my surprize the left side drum was shattered in pieces.This old gal is on 100% steel and has been on display and not driven for years. How big of a job is it to replace a drum? At least I won"t have to remove the old one which I assume helps a bit. Of course I will have to find a used drum first. Are all the gaskets and seals still available? Thanks for any help.
acmfmh
03-05-2005 10:10:45
 Re: WC BRAKE DRUM in reply to Bud W, 03-02-2005 08:41:11
I have replaced the inner and outer seals on my WC. The hardest part was getting the cast section out that the outer seal is in. Mine was machined as a very tight fit. Other side came off easy. Seals are available at AGCO dealer. The inner seal has an upgrade that allows for use of a more common seal. The inner I drove in with a 4x4 post that was two foot long. I had to make the large final drive gaskets from sheet material. I do not know if they are now available.
