WD mag
Jim Z N.D.
02-28-2005 16:51:45
The FMJ mag on my WD is only providing good spark to the #2 cylinder. It has new AC plugs & wires,new condenser and the points have been cleaned and set.Anyone run into this before?
Thanks in advance,
Jim
Steve in N.J.
03-01-2005 11:27:45
 Re: WD mag in reply to Jim Z N.D., 02-28-2005 16:51:45
Jim,
That could be a multitude of little problems causing that. Anything from a bad magnetic rotor to a simple cracked end cover. We service, repair, rebuild, and sell parts for F/M & Wico Mags. Be happy to help you out if needed.....
Steve@B&B
Dave NE IA
03-01-2005 07:13:10
If you have good spark on any one it would probably have to be in your cap. Clean the rotor and cap connecting pionts internal and external. With a mag you should also have solid core wires. A small crack or a dirt film on the cap could cause your problem. There is a product called wire dry that will work as good as a tv comercial for moisture in ignition parts. Good Luck Dave NE IA
Jim Z ND
03-01-2005 20:11:15
 Re: WD mag in reply to Dave NE IA, 03-01-2005 07:13:10
Thanks for the info. I think I"ll try a new cap. If I still have trouble, I will repost.
Jim
