Hydraulics on B Allis Chalmers
David in Tn
02-27-2005 18:53:13
I have had my hydraulic pump rebuilt, when I put it back on what do I need to do to get the air out of the system? Do I need to change the oil I don't know when it has been changed where do you drain it and how much will it hold? I will put a new hydraulic hose on also repack the cylinder. Any advice i would appreciate thank for your help....
Texas Denny
02-28-2005 11:57:42
 Re: Hydraulics on B Allis Chalmers in reply to David in Tn, 02-27-2005 18:53:13
The transmission fluid and hydraulic fluid are the same. I believe the fill point (which is also the check point) is by the clutch pedal on left side of the transmission. Simply fill transmission until oil come out the fill point with 20 or 30 weight NON-Detergent oil. Non-detergent is very important. If you use motor oil, it likely will foam and you will have a mess. I like the 30 weight better becaue I think it is better for the transmission and differential. You don't need to bleed anything. Just cycle the cylinder. It should work.
