need help identifying AC apple harvester motor
Bob Watson
02-26-2005 05:22:04
Help! I'm retoring a almost working apple harvester that is all hydraulic - the 4 cylinder gas motor runs one big pump. I think it's a AC since the radiator has Allice Chalmers on it - but I'm not sure. The # plate is worn off, but the block has "AW 4660 - 3 A20V" on the rear right side as a casting mark. Also the distributor looks weird to me (has an internal coil I guess since only the 4 spark plug wires come out the cap!) It's #S are intact so that might help - "Fairbanks - Morris Type 5 FM X483C", "Ser #5559808" and "Mfgd. for 231181". If I can figure out what it is, then I guess I could get parts to fix it (ring job). If not then I'll have to put some other motor there (MORE work). Can anybody suggest how to solve this puzzle? Bob in El Paso
ANON
02-27-2005 06:43:18
 Re: need help identifying AC apple harvester motor in reply to Bob Watson, 02-26-2005 05:22:04
I know I will here something back on this but here goes--chances are that it is a 201 that was used in the WC & WD tractors since it has a magneto, or the smaller B & C engine which has a 3 1/4" bore and I don't remember the CI size. The 201 will have a 4" bore. Rebuild kits are plenty for either engine.
Bob Watson
02-27-2005 19:18:36
 Re: need help identifying AC apple harvester motor in reply to ANON, 02-27-2005 06:43:18
Thanks - at least it's something! I'm not familiar with those tractor names but I take it there were 2 different engines - one with a 3 1/4" bore used in the 'b's and 'c's and a slightly larger one used in the "wc" and "wd" models (which i have heard of). Do you have any idea of the total displacement or power from these motors in case this one is not salvaglable? Also, the magneto distributor worry's me a little bit since I've never seen it in a motor this size before. Once I get the motor opened up then I'll need to make a decision about rebuilding it or replacing it with a small auto motor. I would prefer rebuilding it so that I don't need to change the dirict drive hydraulic pump mounts!
steve(ill)
02-26-2005 14:54:46
i dont recognize the motor casting number. you are describing a magnito ignition , not a distributor ignition. your magnito works more like a small lawn mower motor. gets its spark as the motor revolves. you dont need a battery to get it to spark. you are right, the coil is in the magnito. FM was a common distributor for all tractor models. ask you question at Allischalmers dot com and the guys there may recognize the casting number.
