hydraulics on AC 200
Chad Chamberlai
02-25-2005 11:50:48
IN my 200 i have loader and when I would us it to haul hay it would kick out when picking up a bale I was told that it was a relief valve which cost $253.00 so I bought it and now when it lifts fine till it gets 3/4 of the way up and slows down to a stop the relief valve is pre set at 2000psi should it be turned up???
Joe(TX)
02-25-2005 18:45:47
 Re: hydraulics on AC 200 in reply to Chad Chamberlain, 02-25-2005 11:50:48
Are you using the rear remotes on the tractor to operate the loader? If so, The remote valve on the tractor has an adjustable kick out for each section. The service manual shows the adjustment procedure.
