Allis 160 Tractor
Steve Borts
02-24-2005 21:13:53
I have a One-Sixty Allis with the 3 cylinder Diesel Motor. We have been completely thru the motor and everything works great except for the Hydraulic System. It has no major leaks, but if you let it set for any amount of time, the hydraulic system looses prime. I've changed the Fluid, changed the filter and screens, and checked the fluid level. After I get it primed again, they are as strong as ever, so I don't think the pump is bad - just loosing prime somewhere. Thanks, Steve Borts, Jamestown, MO
Dsl
03-05-2005 17:17:23
 Re: Allis 160 Tractor in reply to Steve Borts, 02-24-2005 21:13:53
Like the other posts say, your pump seal--and maybe even the shaft are worn. I have new 160 pumps in stock.
Steve Borts
03-08-2005 13:57:33
 Re: Allis 160 Tractor in reply to Dsl, 03-05-2005 17:17:23
How much do you want for a new pump? Does this include shipping, and where are you located?
Thanks
Steve Borts
Jamestown, MO
Max IN
02-25-2005 15:57:39
Steve Borts Work for AC dealer the pump drive shaft seal is bad then you loose prime
Max IN
02-25-2005 16:00:51
 Re: Allis 160 Tractor in reply to Max IN, 02-25-2005 15:57:39
Steve made mistake in message ---- I work for AC dealer Max
Paul Baxter
02-25-2005 09:19:26
It took a new pump to fix this problem on my 160.
Chris(WA)
02-25-2005 07:24:42
I know its no help but mine does the same thing but only when it is parked facing down hill!And only after sitting for many days. I always wondered if it had to do with the intake of the pump being exposed or something on that order.Maybe a crack in the suction line? I just keep it parked level or up hill when I leave it for a while and it seems fine after that.
