WD 45 won't run
Richard D.
02-24-2005 16:59:50
My 1953 WD 45 has for the past several months been coughing and sputtering. Lately, I"ve had to run the choke at about half throttle. One day it just quit, and now if it sits long enough it will start for a second, and then quits and won"t fire up again. It turns over, but it won"t run. Can someone please help me. Thanks.
Josh T.
03-01-2005 07:00:33
 Re: WD 45 won't run in reply to Richard D., 02-24-2005 16:59:50
You have an obstruction in the jets of your carborator causing it to run lean. Pulling out on the choke causes less air to enter the carborator making the mixture richer again. If you had an obstruction at the sediment bowl it would cause the engine to run slower not need more choke.
farmweld
02-25-2005 18:57:22
sounds like a fuel delivery problem if you have to run the choke that much. try clenaing out fuel passages in the carb.
farmweld
BushogPapa
02-25-2005 05:20:54
If you have good fuel flow, then you need to drop the float bowl part of the carburetor and clean the fuel passages in the bottom of it.. Remove the Power Screw and make sure fuel can flow thru the passage leading to it... Make sure the float is free, and the needle is not "sticking" in the seat.... You can drop this part off with the carb still on the tractor...
Ron.
Steve in N.J.
02-24-2005 21:09:24
Rich,
Could very well be a fuel delivery problem. Especially the part about when you pull the choke out to keep it running. Sounds like it's time for a fuel delivery inspection. One way to check is take the plug out of the bottom of the fuel bowl of the carb, put a jar under to catch the fuel and open the sediment bulb petcock and see if you get a steady stream of fuel. If not, there's a blockage somewhere up stream. Could be in the tank or where the elbow screws in to the carb inlet. That's a trouble spot. Where the sediment bulb goes into the tank is another trouble spot. HTH.
Steve@B&B
Jason Melzer
02-24-2005 20:10:12
I had the same problem with mine I found that the inlet for the sediment bowl was pluged up. I just replaced the whole thing and every thing was good to go. hope that helps you
