AC B rod bearings
Steve Clark
02-24-2005 08:23:51
After receiving great insight to my AC b knocking symptom, I pulled the oil pan and examined each bearing and rod journal. The top bearings were all flaking, the bottoms were intact. The crank journals seem to be smooth ( #2 has a small scratch ). I have smoothed the journals, measured each journal with a micrometer and replaced the bearings with standard size. My question - is it normal for the top bearings to wear or is it a symptom of something else like a main bearing problem. The B is a 1939. Not sure if bearings are original but I have had the tractor for 15 years and it has never had a problem. thanks
Ed H.
02-24-2005 20:06:54
 Re: AC B rod bearings in reply to Steve Clark, 02-24-2005 08:23:51
I found the same thing on a '42 C, I would'nt worry about it...just put in new bearings, and use plasti-gauge and remove or add shims the get the clearance to around .002 to .0015....make sure you get the rods in the correct way...check your manual
Dick L QUESTION
02-24-2005 11:22:55
Did you check the bearing clearance with plastigage? You should not have much more than .002 clearance. If you have not checked the clearance, I would not start the engine. I personally have never been able to replace a bearing on a rod that has been knocking.
elwoodcliff
02-24-2005 10:36:28
I'm guessing it is and oil pressure, blockage problem?, Although whers the bearings which you removed a pair or did some joker replace the bottom bearing and not the top for some reason?
