Brakes on AC 200
Chad Chamberlai
02-20-2005 15:28:51
Hydraulic oil is leaking onto my brakes is this a big job to fix?
Jr64
02-20-2005 19:49:48
 Re: Brakes on AC 200 in reply to Chad Chamberlain, 02-20-2005 15:28:51
Not really. Pull the cover off the brakes, disconnect the bracke linkage, pull the disc assembly out and you can replace the seals. Inconveniences could be encountered depending on what your wheel spacing is and if there"s any cab brackets in your way but regardless, it"s not a bad job.
Jr64
02-20-2005 19:52:40
 Re: Brakes on AC 200 in reply to Jr64, 02-20-2005 19:49:48
I should have explained that the disconnecting brake linkage consists of screwing out the adjusting bolt from the disc linkage.
