allis B 1st oil change
Tom Farrell
02-19-2005 10:56:23
1949 allis b need info on motor oil weight / transmition oil type also oil for air intake canister and how much . thank you
Robert in Md
02-20-2005 17:50:44
 Re: allis B 1st oil change in reply to Tom Farrell, 02-19-2005 10:56:23
My AC B with hydrolic pump takes 20 wt oil in the diff. and transmission.
gene (Missouri)
02-19-2005 19:32:29
Engine oil, 30 wt detergent, add 4 quarts run engine until oil pressure comes up. Then add oil to full line. Transmission differential 6 quarts of 80/90 wt gear lub - Add 1 quart for PTO. Final drives 3/4 quart 80/90 gear lub.
Air cleaner oil cup, engine oil, full line mark on the side of the cup, will take about 1/3 quart.
My opinion. There has been some discussion on which engine oil to use.
Tom Farrell
02-19-2005 21:34:07
 Re: allis B 1st oil change in reply to gene (Missouri), 02-19-2005 19:32:29
re allis 1st oil change thank you for info.
Dennis Andres
02-24-2005 14:42:48
 Re: allis B 1st oil change in reply to Tom Farrell, 02-19-2005 21:34:07
The transmission oil needs to be 20w not 90w gear lube.The rest of the info is correct.You can also substitute universal hydraulic-trans oil of similar weight.That is what I use.The heavy weight 90 will cause your hydraulics not to work at cooler temps.
