wd rear lift arms
B in Iowa
02-18-2005 17:44:25
Friend of mine has a wd45 that the lift arms won't go down,also if you hook up a remote cylinder it will blow the seals out of the cylinder.Any help is appreciated since I'm a farmall owner. Thanks!
Allyn in OK
02-22-2005 21:02:11
 Re: wd rear lift arms in reply to B in Iowa, 02-18-2005 17:44:25
Mine has the same problem. I am pretty sure it is a linkage problem but haven"t had time to figure it out. I may not have to if somebody will bid on it (eBay item 3876197646).
bw in mo
02-18-2005 19:27:34
The lift arms may not go down on their own. the reason you blow the seals the WD45 is high presure, like 3500 psi. you may be useing a low presure cylinder, not an AC cylinder. You will need the high presure cylinder made for AC before 1959.
B in Iowa
02-19-2005 15:55:33
 Re: wd rear lift arms in reply to bw in mo, 02-18-2005 19:27:34
When you said they may not go down, how are you supposed to hook up your plow,or blade?We can't force them down.
Greggie
02-19-2005 18:53:26
 Re: wd rear lift arms in reply to B in Iowa, 02-19-2005 15:55:33
BW meant they won't typically lowerr on their own without a load when you pull the lever down... If you can't force them down, you definitely have a problem and I'm sorry, but I don't have the knowledge to help you farther than that.... Good luck and I'm sure there'll be someone pipe up that knows these tractors better than me.
Greg
