water pump wd45
K T
02-15-2005 14:11:20
can you get parts to rebuild the water pump on wd-45 or is it just as well to get a rebuilt one
Steve in N.J.
02-15-2005 18:38:28
 Re: water pump wd45 in reply to K T, 02-15-2005 14:11:20
KT,
You're better off installing a brand new pump. Rebuilding those old pumps did nothing but make you go back later and tear things apart again to do the job over once more. We have brandy new pumps in stock which are very reasonable and American made. Drop us a line if interested....
Steve@B&B
Tom in Michigan
02-15-2005 15:55:39
KT, There is a kit available and is probably (?) cheaper then a rebuilt pump. Having a press is necessary to remove and install bearings, etc. You may want to replace the fan belt and hoses since your right there. Tom
KT
02-15-2005 17:12:51
 Re: water pump wd45 in reply to Tom in Michigan, 02-15-2005 15:55:39
Thanks Tom; I'm doing a out of frame overhaul so it will be easy to do ,. where would one find the kit? Thanks again. Ken
Tom in Michigam
02-16-2005 03:52:03
 Re: water pump wd45 in reply to KT, 02-15-2005 17:12:51
KT, The last kit we got was from our Allis dealer. You may also consider following up on the post from Steve. If he has a source of serviceable/rebuilt pumps that are reasonably priced, it is also an option to explore. Tom
