WD 45 brake problem
rwh
02-14-2005 22:53:16
I am trying to do the brakes on my wd. The anchor pin seemes to be seized in the hole.
Is it just the lock (the 1 1/2" flat steel holding the head of the pin) that holdes the pin in place or am I just missing something else. I have tried anti seize spray's but it wont come loose. Do I need to use heat or do I have to remove the rim and rear axle to get at it.
JC(WI)
02-17-2005 22:47:22
 Re: WD 45 brake problem in reply to rwh, 02-14-2005 22:53:16
Just had the brakes out and put them back in a couple weeks ago. Had them out 20+ years before that. I had put a little grease on the pins at that time and they came out real nice this time. The other time I had to soak the pins both outside and inside and took a wreaking bar and ground a notch in it to fit under the lip of the pin. Then had some one pry on the pin while I sprayed more penetrating oil on and rapping the head of pin until it started to move. Have seen actual pin removal tools for the job too, but I don't know where to get one anymore.
Gary Rainbolt
02-16-2005 06:16:44
brakes how to rebuild
wdtom
02-15-2005 18:20:46
I have posted how to remove really tough ones several times, check the archives. If no luck, e mail me. If you do get them out, drill and tap a 3/8-24 thread in them to make it easier to get them out another time. Drill and tap it deep enough to get past the neck, it is possible to pull the end of the pin off at the neck if the thread doesn't go in past it 3/8" or so.
JMS/MN
02-15-2005 07:59:29
Rusted in pins are common. Use penetrating oil and a torch to loosen them. If still tight, I drill a 3/4 inch hole in a 1/4 by 2 flat iron, and weld it to the pin. Makes a nice handle to wiggle it out, and the heat of welding helps to loosen the pin. When it's out, grind off the weld and re-use the pin, with anti-sieze.
Tom in Michigan
02-15-2005 07:11:17
RWH, The pin is anchored as you described. I have had to cut the pin out with a torch to remove the brakes, and then finish removing the pin with a torch, punches, etc. Not an easy task, but it can be done. Use anti-siege on the new pin when you replace it. Tom
