weekend work on my G
souNdguy
02-14-2005 05:17:31
I actually had a full day to work on the G this weekend.
I finishe dup the buld of the painting, including repainting the rear cowl on the tractor. I bufffed, primed and shot the fenders, battery box, and lid, and also finished the rear rim and center. Just need to bolt those items on.. and look for areas to touch up paint.
I painted the steering wheel flat black, and went with hi-temp black on the muffler.
Looks like it will be ready for decals by next weekend hopefully.
Soundguy
Phill Snartland
02-14-2005 13:24:53
 Re: weekend work on my G in reply to souNdguy, 02-14-2005 05:17:31
It sure has been fun to see your progress photos. It's looking like a fine machine. Keep sending the snapshots.
Phill
souNdguy
02-14-2005 18:23:39
 Re: weekend work on my G in reply to Phill Snartland, 02-14-2005 13:24:53
Thanks.
My next day to spend some time with it will be wednesday after work, as I pull a double tomorrow.. 7am-10:30pm
I got about 3 hours on the G today, and got the fenders installed, removed the cobbled up battery tray the previous owner made.. cleaned up the battery and terminals, and installed the new box, and lid. My welded up new floor for the battery box fit perfectly and hold the battery good.
I opted to go with 1/8 metal dowel rods to re-create the choke pull rod and the starter pull rod that go thru the fenders. The both work great. I used a large 1.25" piece of round stock as my bending template for the finger loops. I got them as close to 'matched' as possible. if you look them over close you will see minor differences.. but what the heck.. I couldn't find originals anywhere. I had previously primed and painted the rods, so all I had to do was touch up the paint were the bend was. I installed a 6v headlamp on a cir-clamp bracket where the upright steering column support meets the steering tube. Wired it up to the OEM headlamp switch and it worked great! I thought about adding a tail lamp.. but with a quick check of the ammeter, the ignition and 30w 6v lamp draws 8.5 to 9 amps. My service manual says that genny is capable of 9.5a max.. so I'm at the limit with the single headlamp. I see pics of a small bullet style lamp inthe rear as well as a headlamp.. so my gues sis the oem headlamps must have been like 20 - 25 w instead of 3.. and the rear lamp must have been just a 5-10w red bulb.. cause the genny wouldn't do any more than that.
I mounted the last rear rim and center that I painted this weekend, and pulled the jackstands out, so she's standing on all her own rubber now.
At this point all she lacks is some touch up paint ont he lugnuts, and fender bolts, some on the headlamp bracket nut, and then decals, and then the padded orange seatcushion. Perhaps wednesday will be the 'finish' day?
In any case, I'll get some pics then, finished or not.
Soundguy
