WD-45 Tune Up
Martin Miller
02-13-2005 17:49:00
I have a 1955 Allis Chalmers WD-45 that is in need of a complete tune up. What are some things to check out and/or replace besides plugs, plug wires, points, condensor, coil etc? I would appreciate any help.
jra
02-14-2005 07:53:11
 Re: WD-45 Tune Up in reply to Martin Miller, 02-13-2005 17:49:00
You may want to check your manifold, they are bad about warping and sucking air, I have had to have two of them plained down to get them to seal.
Steve in N.J.
02-13-2005 19:03:08
Martin,
Check to make sure there isn't any side to side movement in the distributor's main shaft. If you can move the shaft back n' forth holding on to the rotor, it needs a rebuild. If it doesn't move your okay. We offer a complete tune-up kit for your WD series machine if interested. Drop us a line. We also offer complete distributor and mag rebuilding services..
Steve/B&B Custom Circuits
[email protected]
