Latest on the G
souNdguy
02-12-2005 22:17:27
Finally got my last box of goodies from the big brown truck. Technically I'm still waitingon the decals as they were back ordered.. but they are a finishing touch item.. not real bolt on parts like the rest of the stuff I needed. Well today and yesterday i did some more painting, and also worked ont he other rearrim, and the battery box. I got a couple runs on the rear cowling, and am going to sand it back down once cured for a few days, and reprime and paint. The battery box needed help bad. I ad to weld in a new lit for 1.5" angle iron on one side, and then add two stiffeners from 3/16 plate to beef up the lower mounting bracket, as well as adding a new expanded metal floor. That said.. I finally found a good use for 1/16 rods and the 30 amp setting on my little stick welder. Even then you had to be creative with that very thin sheetmetal.. felt like i was welding a soup can...
I'll probably finish up the battery box tomorrow, and then do some more painting on the rear rim, and then start on the fenders.. looks like they will need almost as much attention as the battery box. Battery box lid seems fine...
Soundguy
