C Water Pump
TX Denny
02-12-2005 13:39:36
I read the archives and found out about oil pump priming and it worked as said. If you were one of the original writers, Thank you.
I'd like to lubricate the bearings on the water pump. Is there anyway to do this without taking the pump apart? The pump does not leak and the bearings feel tight.
Thanks,
steve(ill)
02-12-2005 20:13:55
 Re: C Water Pump in reply to TX Denny, 02-12-2005 13:39:36
listen to Dick. the bearings are sealed and the inner race is actually the shaft. if you try to get it apart you will surely screw it up. it is more trouble to rebuild than it is worth.
Dick L
02-12-2005 15:39:18
NO way to do that. They are made to never be lubed.
