WD45 ext drawbar to attach a JD 38B mower?
IowaPaul
02-09-2005 17:55:28
Hi all, I found an old JD 38B sickle mower that I"d like to hook up to my WD45. Challenge is the extension drawbar that came with the mower is for a JD 3010. A quick review of the mower manual shows a simply designed drawbar - essentially two arms that extent straight out from the tractor and one bar that runs perpendicular at the end of the arms. I haven"t had any luck finding a used drawbar, and calling around to the local dealers hasn"t turned anything up. A visit to the local JD dealership to see if they had specs for this drawbar was as fruitless. With a friendly neighbor"s help I should be able to weld something together. I can measure the width between the arms, but I need to know how long the arms should measure. Comments appreciated. Paul
JMS/MN
02-11-2005 11:27:46
 Re: WD45 ext drawbar to attach a JD 38B mower? in reply to IowaPaul, 02-09-2005 17:55:28
ASAE standards for a drawbar/pto hookup are that the drawbar should extend about 12-14 inches behind the end of the pto shaft. Double check that dimension with any tractor operator manual, but I think that is right. Then set the mower behind the tractor, that distance, and you can measure to determine the proper arm length.
