Teeth on a Sickle bar mower ('39 B)
Chris (OR)
02-09-2005 07:26:12
Well I am working on rebuilding a sickle bar mower for my '39 B. I got a whole new set of teeth (the knives that move). The are nice and sharp compared to the rusting ones on there now.... But what to folks usally do when they put on new teeth? I was going to rivet them like original, but do I paint them? Or should I leave them bare steel and spray them with WD-40 every time I use it?
Thanks
Chris Horn
Scappoose Oregon
mj
02-10-2005 09:52:28
 Re: Teeth on a Sickle bar mower ('39 B) in reply to Chris (OR), 02-09-2005 07:26:12
An easy way to get the old sections off the bar is to set your shop vise wide enough to let the sections in but not the bar. Start at one end with the bar horizontal, resting on the vise jaw and the first section in the gap, point down. Now...SMACK it with a 2 or 3 lb. hammer....the rivets will shear right off.
Dick Kline
02-10-2005 09:17:04
First of all the "teeth" as you call them used to be be called knives or sections. The stationary parts points. I agree with everyone lubrication is the key. When I mowed all day, I lubed the sections with motor oil and greased anything with a grease fitting every hour. There is a lot of steel against steel in a sickle bar mower.
I never had much luck holding knives on with bolts, but I didn't have locktite either!
Sheila Cole
02-09-2005 16:34:40
I use old engine oil on my C sickle bar mower, after each mowing.
Bailey
02-09-2005 13:33:28
Hello Chris. I have an original advertising brochure for the A.C. No. 3 Power Mower for sale.Please email me if interested. It was made or the "B", "C" and "WC" tractors. Thankyou. Robert.
John (C-IL)
02-09-2005 07:40:44
We always brushed used motor oil on the sickle when we were done with it.
steveormary
02-09-2005 17:01:55
 Re: Teeth on a Sickle bar mower ('39 B) in reply to John (C-IL), 02-09-2005 07:40:44
And before we started and usually ever hour or so. Had to keep it well greased too. And you can use bolts instead of rivits. steveormary
