WF Sleeves
Gary Peterson
02-08-2005 16:56:22
How smooth does the block need to be where the o-rings in the sleeves seal? I rebuilt the motor and after I had it running I discovered water in the oil coming from the wet sleeves, I pulled the sleeves out and noticed the block is very rough and grooved where the o-rings were supposed to seal? What should I do with this?
TX Denny
02-11-2005 07:51:09
 Re: WF Sleeves in reply to Gary Peterson, 02-08-2005 16:56:22
Don't know easy way to fix but the sealing surface must be smooth or the o-rings won't likely seal good enough.
