WD timming problem
mark wd
02-08-2005 06:38:20
I have a WD but I don"t know what year it is, but we re-dit the tractor it ran fine before, but after it was done it did not like to start, the magneto was taking apart and we came to the conclusion that someone had moved the inside. we took it into a parade, but had to pull it to get it started, can anyone help on finding the year and how to time? thanks
gene (Missouri)
02-09-2005 07:31:23
 Re: WD timming problem in reply to mark wd, 02-08-2005 06:38:20
Timing the WD. Follow the directions posted in timing the WC a few posts earlier.
My guess is that if you can pull the WD to a start that the impulse coupling is not working. You should hear a click in the magneto when cranking the engine over.
farmweld
02-09-2005 05:13:15
sometimes you can use the serial numbers to help find the year. i think in the serial numbers hyperlink are off to the side under research and info. check them out. i timed mine like any other cyl. gas engine.
