WD45 Shifter Problems
gilesmt
02-08-2005 04:46:32
Anybody discovered a fix for a worn out gear shifter? Once the shift lever gets worn it tends to jump between gears. Thought maybe someone has aftermarketed a new/modified system.
bw in mo
02-10-2005 18:47:05
 Re: WD45 Shifter Problems in reply to gilesmt, 02-08-2005 04:46:32
John is correct build the bottom up about 1/8" after grinding back to flat surface. I have had to build up the groves that the little pin fit in the shifter to keep it from turning.
John (C-IL)
02-08-2005 06:07:13
The solution is to build up the end of the shifter and grind a new profile on it. There may be others that can post pictures and specs of the procedure.
.Verle Spence
02-15-2005 20:12:07
 Re: WD45 Shifter Problems in reply to John (C-IL), 02-08-2005 06:07:13
I took mine to the local AC dealer and it cost $45.00. They built up the end of the shifter & then ground it down to fit in the slides for the gears.
