WD WHEEL WEIGHTS
COLIN MCAFEE
02-05-2005 17:08:17
I HAVE TWO REAR WHEEL WEIGHTS THAT I AM NOT SURE IF THEY WILL FIT WD. DOES ANYONE KNOW WHAT THE CORRECT CASTING NUMBER FOR REAR WHEEL WEIGHTS FOR A WD WOULD BE?
Brian G. NY
02-06-2005 18:32:38
 Re: WD WHEEL WEIGHTS in reply to COLIN MCAFEE, 02-05-2005 17:08:17
The casting number on the original WD/WD-45 rear wheel weights is: AM2795-10
Texas Denny
02-06-2005 09:09:13
Measure the spacing of the holes on the wheel hub and the weight. If they are close to the same, they should fit. I know those from a WD and WD-45 are the same. I think those from a D-17 will fit as well. Don't think the ones from a D-14 and D-15 are the same because wheel diameter is 26 instead of 28. However, they may still fit.
