Allis C timing
Richard H.Gambr
02-04-2005 14:58:28
Trying to time a magneto on an Allis C.
Do I time it to the FIRE mark on the flywheel or the CENTER mark.
I could really use some advice on how to time this tractor. Sorry, I am a John Deere man. If someone could help me as to where the rotor should be with which mark, I would really appreciate it.
Thanks, Richard
Duey (IA)
02-04-2005 20:46:09
 Re: Allis C timing in reply to Richard H.Gambrell, 02-04-2005 14:58:28
Richard,
I have some pictures on my web site and some instructions.
Duey
Richard H. Gambrell
02-05-2005 05:40:38
 Re: Allis C timing in reply to Duey (IA), 02-04-2005 20:46:09
Thanks Duey,
That is a very informative article on timing. I had never noticed the lug in the cap before.
Thanks again, Richard
Rod (NH)
02-04-2005 16:57:58
Hi Richard,
You use the "center" mark unless you are using a timing light with the tractor running, in which case you would use the "fire" mark. If you want more detailed insructions on magneto ignition timing, click on my name and check out my two links on the FMJ magneto. It's for a B but the C should be the same.
third party image Rod
Richard H. Gambrell
02-04-2005 18:30:32
 Re: Allis C timing in reply to Rod (NH), 02-04-2005 16:57:58
Thanks Rod,
That is what I needed to know. I really like your website.
I have a very hot spark on the mag on the work bench, I just needed to know how to set the engine timing.
Thank you, Richard
