allis engine
chad mn
02-04-2005 05:14:50
i just bought an allis and was told it was a wd45. upon cleaning up the motor i found the stamped #s on the block and it says it is a wd. from these part #s can anyone tell me if these are wd or wd45? crank 226535.... rod atlas 23 u-3988... piston ge31x....thank you in advance for any information
John (MO)
02-04-2005 08:21:36
 Re: allis engine in reply to chad mn, 02-04-2005 05:14:50
A WD block has removable side plates on the block behind the carb. A WD-45 block does not have these plates, the block is solid in this area. In the 50 plus years since the tractors were build, many WD blocks have been put on WD-45 tractors and maybe even more WD-45 blocks have been put on WD tractors. I'm sorry I don't know what your part numbers stand for. It has been fairly standard practice for years and years to upgrade WD engines with WD-45 internal parts like cranks, pistons and sleeves.
Eldon (WA)
02-04-2005 08:49:19
 Re: allis engine in reply to John (MO), 02-04-2005 08:21:36
John there is only one side plate on the 'WD' engine and it is on the mag (right) side of the engine.
