In my opinion, which is worth what you are paying for it, 8 volt batteries are not a good idea for anything. First of all, if starting is the problem, then start by fixing the problem you are having while using 6 volts. The usual culprits are poor battery and cable connections or worse yet, using cables rated for 12 volts on a 6 volt system. Check your charging system too. If it doesn't work on 6 volts, it will be even worse when trying to maintain an 8 volt battery. Think about your stand-alone battery charger too - ones that will work at 8 volts with a flip of the switch are far and few between. The next issue is the one you already mentioned: compatability. The truth of the matter is, if you are considering going to electronic ignition, just convert the tractor to 12 volts. There are some 6 volt electronic ignition systems available, but once you purchase one, you are locked to a 6 volt system forever - unless you change electronic systems too. I'm not certain, but I'm willing to bet that any electronic ignition supplier will not warranty their ignition system if it is not used at the voltage for which it is rated. I'm sure other opinions will follow mine which will differ with me, but remember it is your $$$ that will be invested in this. I've always had an easy time telling someone what to do when the money they were spending wasn't mine.
