Looking for Modle Number
Steve Fischr
01-29-2005 07:41:56
Found a A/C but can't find modle number only fond a SER#B23345 in front of gear shift. Has wide front end, and bench seat. Would like to kown modle and value of A/C.
Thank You
Steve Fischr
d. taylor
01-31-2005 15:25:55
 looking for allis chalmers g in reply to Steve Fischr, 01-29-2005 07:41:56
looking for allis chalmers g model
JK Graves
01-31-2005 13:49:22
 Re: Looking for Modle Number in reply to Steve Fischr, 01-29-2005 07:41:56
can not find serial number on WD-45 need find year modle
Steve Fischer
01-30-2005 11:06:13
Thanks so much for all the infrormation it was very helpful... Thanks Again.
Steve Fischer
steve(ill)
01-29-2005 20:20:27
steve- if you have specific questions and want to ask direct--- [email protected]
steve(ill)
01-29-2005 20:18:34
it is a model B about 1939 model. probably has hand brakes, a pto shaft, myabe hydraulics, put probably not. it is a 20 HP tractor with 3 speed transmission. if it has a generator and electric start it is worth a little more than the hand crank version. Since it is a 39 it might have the 116 cubic inch motor instead of the 125 model. look at the side of motor where to bolts the the torque tube and see the motor number BExxx is the little motor. CExxx is the newer motor staring in 1940. a basic tractor that runs bout is poor condition will be about $600. straight sheetmealt, all parts, dull paint but no beat up might be $1000. has to be electric, have hydraulics, minimal leak, decent tires, etc to get up to $1200-1500. Normally not higher unless motor is rebuilt and have new paint.
bryan g in mo
01-29-2005 08:11:18
looks like you have a model B tractor, at the home page here you'll find a serial number listing under research and info, that will tell you the year.
