Key or pushbutton switch for a HD-7W
Dave (Northern
01-26-2005 15:27:38
I need to replace the ignition switch on a 1943 GM 371 (Diesel) starter. The starter is electrically operated, in other words, it does not use the manual plunge pedal starter.
What kind of push button switch would I need to buy? Any special voltage or amperage requirements?
Any idea where this could be purchased? Can it also be converted to a keyed ignition?
Lee Bradley
01-27-2005 10:59:23
 Re: Key or pushbutton switch for a HD-7W in reply to Dave (Northern Calif), 01-26-2005 15:27:38
Dave,
The current draw is pretty high on those starter solenoids. So I add a Ford type remote solenoid to switch the current to the starter and control the remote solenoid with a dash push button or keyed switch with start position. Any parts store should be able to help you with these parts.
cdmn
01-26-2005 22:29:47
I suppose this could be a trick question. Diesels don't have ignition switches. But you could find a starter switch from any other tractor or garden tractor that will fit the space you have. If it's from a gas tractor, you just don't use the coil wire connection. I've been having trouble with dimestore ignition switches lately. Seems like they don't connect in cold weather. Works good if I use the heat gun to warm it up.
