WC Allis Water in oil 1947 model
rodger
01-25-2005 19:12:37
any hints
gene (Missouri)
01-26-2005 11:49:10
 Re: WC Allis Water in oil 1947 model in reply to rodger , 01-25-2005 19:12:37
You might try some of the better block sealers available at the auto parts store. Some are designed to seal leaking head gaskets and cracked blocks. You need to follow the directions for the product you purchase. If this doesn't work you are out only $6.00 to $8.00.
BushogPapa
01-25-2005 21:12:44
Sure..how much water..???
Just a noticeable trace on the dip-stick..??
Might be ( and probably is) a cracked web between either the #1 and #2 or #3 and #4 sleeves.
If it is not getting much moisture in the oil, it should be good for years... There are ways to stop that problem without tearing it all down, too..
Let us know what you have.. Ron.
Andrew Z
01-26-2005 10:25:36
 Re: WC Allis Water in oil 1947 model in reply to BushogPapa, 01-25-2005 21:12:44
I have a Allis B that had water in the oil it turned out to be the "O" rings had let go. It was very noticable beacuse the water level in the radiator would drop 2" over night. Andrew
