D17 Series IV
midas
01-25-2005 11:08:15
I am going to an auction to look at a 1963 D17. Can anybody tell me when the transition from Series III to Series IV occurred and what the major differences are? Thanks
Mike in Ohio
01-25-2005 19:35:14
 Re: D17 Series IV in reply to midas, 01-25-2005 11:08:15
According to Terry Deans book the series IV started in 1964 at serial 75001. If it is a 1963 it must be a series III according to this book. Hope this helps Mike
wolfmantractor
01-25-2005 19:34:54
I have a 1963 which is a series III. I think series IV came out in 1964. Maybe late 63. Best to look for the hydraulic pump-if located on right where belt pulley was on earlier 17's, then it is series IV. Series IV's could have a big heavy factory 3-pt OR a snap coupler. Series IV's also had side console hydraulic levers on the right. Also the high volume, low pressure hydraulics(industry standard).
midas
01-25-2005 18:20:36
Thanks for the infomation - would you know if the the Series IV was manufactured as early as 1963?
Gatz
01-25-2005 20:25:28
 Re: D17 Series IV in reply to midas, 01-25-2005 18:20:36
midas
according to Terry Dean's book...
SerIV came out in 1964 beginning at s/n 75001.
There were 14,213 made ending in 1967
Gatz
Jerry from East Iowa
01-25-2005 11:35:49
Hi
The single biggest difference is the hydraulics.They went to a pump mounted where the belt pulley used to be and went to normal hydraulic pressures and volumes like everyone else had.Hope I could help. If you have any other questions e-mail me at [email protected] or call me.
Thanks,
:) Jerry
Jerry's Tractor Repair
Holy Cross , Iowa
563-552-1615 or 563-590-1973
Gatz
01-25-2005 12:00:28
 Re: D17 Series IV in reply to Jerry from East Iowa, 01-25-2005 11:35:49
The Series IV could be equipped with industry standard Cat-2 3pt lift OR the earlier SnapCoupler system. (I don't know if the SerIII had this option.) It the one at the auction is a 3pt , it will probably bring good money but would be worth it.
Gatz
