Allis B cooling system
Nick R (Wi)
01-25-2005 06:00:04
I'm fixing up a 53 Allis B. I has shutters. After taking apart the cooling system for cleaning and resealing I notice there is no thermostat or a place for one. Are all B that way and if so how does the engine stay hot in winter temp like here in Wisconsin. I also have noticed that the shift level can spin around. How does the lever come out for possible repair. Thanks guys. Nick.
Dick L (PICTURE)
01-25-2005 12:48:29
 Re: Allis B cooling system in reply to Nick R (Wi), 01-25-2005 06:00:04
Here is a picture of where you can see the thermostat dial on the front top of the head above the thermostat housing. Picture is a little dark but you should be able to see it.
third party image
The below picture is of the thermostat housing upside down to show the thremostat.
third party image
CH Upstate NY
01-25-2005 11:42:34
If it's a '53 it should have a thermostat. On the front of the head, there's a small housing that has the upper radiator hose attached. Two bolts hold it to the head and after you take it off there's two bolts that hold a plate. Inside is a spring and the thermostat.
